Using Pre-Computed Permeability Data by using “Setup Link …” in the “Solve Setup”
    • mabdelraziq
      Greetings all,
      I am simulating two WPT circular spiral coils with Permanent Magnets (PMs) at the center of each coil as shown below:
    • Deyu Li
      this error is pointing that two designs have different geometries. I would suggest you copy the eddy current design and paste, simply change the solution type of the pasted one to magnetostatics. See if this error still exists.
    • mabdelraziq
      Did that, still the same issue...
