May 31, 2022 at 4:50 pm
ydeniz
SubscriberHello I am trying to use radiation efficiency in the calculation of an output variable that I'm setting, for example, sqrt(RadiationEfficiency).
When I try to do that, I get the error "RadiationEfficiency" is not a defined variable name in this context.
How can I get past this error and use radiation efficiency in my calculation?
Best.
July 5, 2022 at 1:34 pm
Zeba Naqvi
Ansys EmployeeThe only way I can reproduce this error is when wrong context is chosen - say Modal Solution Data instead of Antenna Parameters. Perhaps you are typing the expression out. If you select the correct context, it should accept it.
- Maxwell, HFSS or Q3D?
- Error
3646
2512
1737
1226
578
