September 4, 2019 at 4:53 pm
mateusr
SubscriberDear all,
I have a system composed by two bars connected by a pin at the center, like a scissor. I would like to calculate the bar separately and after the calculation of the first bar, use the reactions at the pin in the other bar.
How can i import the reactions to the the other model?
This is just an example. The system is way more complex and i would like to use this idea for some preliminary analysis until the component is under development.
Ps: at this moment i just want to evaluate it statically in a certain position with all the forces and supports involved in the case.
Thank you for your support.
2142
1355
1144
462
