July 26, 2018 at 11:13 am
suraj9735
SubscriberThanks, Peter!
It really helped me.
Now next I want to put heat flux on or off according to programmed control.
I want my model maximum temperature should not exceed 180 deg and also not fall below 175 deg.
how to put logical heat flux load like below
0
180 deg=1500 Watt.
Temp>180 deg=0 Watt.
Thank you!
July 26, 2018 at 11:14 am
SubscriberThis new discussion was moved from the tail end of a solved discussion.
Suraj, I don't know how to do this, but will be interested to find out.
August 22, 2018 at 2:05 pm
Mike Rife
Ansys EmployeeHi Suraj9735
There is a 'combination' element in Mechanical APDL that can act as a thermostat. See the two part blog entry on this at PADT - the link to part 1 is:
http://www.padtinc.com/blog/the-focus/act-extension-for-a-pid-thermostat-controller-part-1
Mike
2066
1285
1096
459
