March 21, 2021 at 2:56 pm
Alvin
SubscriberHi, I am currently modeling heat and mass (moisture) transfer using UDS scalar as moisture inside a kernel. I used the equation hm*(Ms-Ma) at the air-kernel interface, where hm is convective mass transfer coefficient, Ms is surface moisture (also Scalar 0) and Ma is air moisture (UDM 0). For some time, the moisture of the kernel is dropping as it is being dried by hot air, but at some point, the exponential drying curve changes into a different and unrealistic graph. What seems to be the problem? And how can I fix this?nn -
March 22, 2021 at 2:57 pm
DrAmine
Ansys EmployeeQuite hard to deliver here a guidance without knowing to certain extend: which models are involved and how are you defining the mass transfer via UDF. Also please describe the problem.n -
March 25, 2021 at 1:07 pm
Alvin
SubscriberThank you for replying nI'm using Ansys Student 2020 R2, I used expressions to create the mass transfer equation instead of using UDF. I used a converged steady state solution before modelling transient heat and mass transfer. The simulation solves for continuity, energy, turbulence (bcoz of SST k-omega model) and UDS. I monitored the simulation by plotting the vol average of Scalar 0 (moisture content) over time. As you can see in the pictures, it started fine, showing exponential trend, then after some time, the trend changes into an absurd one. What could be the reason behind this??n
March 26, 2021 at 1:56 pm
Ansys EmployeePlot the expression and see if there are any oddities in it's behaviour at certain temperature, pressure or mass fraction conditions. n -
March 28, 2021 at 8:36 am
Alvin
SubscriberHi thanks for replying.nwhen you say plot the expression, do you mean the named expression? or the variable such as scalar 0??n -
March 29, 2021 at 1:45 pm
Ansys EmployeeAny and all expressions that are used to set properties or boundaries. It may be something else is causing the problem, but it's often a badly defined curve/profile or sudden step in values that then causes the solver to diverge. n
Viewing 5 reply threads
Trending discussions
Top Contributors
2564
2068
1289
1106
459
Top Rated Tags
