March 6, 2023 at 6:48 pm
Miguel
SubscriberHi,
When using weak-springs (on or programme-controlled), after checking their reactions in results, how much these reactions should amount for in order to consider that they do not affect the rest of the results and the obtained solution is therefore valid? Is there any criterion to follow?
Thanks.
March 6, 2023 at 9:47 pm
Armin Abedini
SubscriberHi Miguel.
I believe it depends on the application but the general guideline is that the reaction forces of weak-springs should be close to zero as much as possible.
Here is a link to a lesson that you may find helpful:Verifying and Validating the Model Setup - Lesson 1 - ANSYS Innovation Courses
March 6, 2023 at 11:25 pm
Miguel
SubscriberThank you Armin. I´ll check it out.
3852
2629
1859
1252
600
