UVL Load in Ansys Workbench (Uniformly Varying Load)
    • PrabhuManickam
      I want to know how to apply Uniformly Varying Load in Ansys Workbench.
      Can anyone help me to find out the result for this problem.
      Urgent.
    • Karthik R
      Administrator
      If you are solving this on the Mechanical Solver, then you should have a table appear to the bottom right corner of the screen when you select the load. There are several rows and columns there. The idea is to go in and populate the entries there. You should be input your entires there.
      I hope this helps.
      Thanks.
      Karthik
    • PrabhuManickam
      For 1D Analysis we able to give line pressure only. On that case, I cant able to give UVL Load.
      If I apply line pressure - Define by Components - In Y Direction - Independent variable is time and step only, I am not getting the distance in that place.
      So Solving UVL in a 1D problem is not possible with that. Can you suggest any material or steps or tutorial for that or can you share any image so that may doubt will be cleared.
    • peteroznewman
Viewing 3 reply threads
