January 26, 2021 at 4:00 pm
NathanEmery1
SubscriberHi Everyone,
I am wondering if there is a way to study V skew techniques in Maxwell.
I am using an IPM motor and have successfully used the built in skew tool for continuous and step skew like in the image below.
January 27, 2021 at 5:31 amNavya C
Ansys EmployeeHi @NathanEmery1
V skew cannot be modeled in Maxwell 2D as the available skew modeling in 2D supports continuous and stepped skewing as of version 2020R2.
For V-shaped Skew model Analysis, you need to perform 3D modeling and import the 3D model to Maxwell 3D.
Note: In the upcoming version 2021 V-shaped skew and user-defined (arbitrary) skew models are being implemented for 2D maxwell simulation. This might be available in public release soon.
Regards
Navya
January 27, 2021 at 2:33 pmNathanEmery1
SubscriberHi Navya,
Ok thank you very much for the reply.
I look forward to the 2021 version.
Thanks,
Nathan
- Maxwell, HFSS or Q3D?
- Error
5364
3363
2471
1310
1018
