November 16, 2018 at 11:51 am
Max4
SubscriberHi everyone,
As an attachment, an illustration of the problem. This models a cylinder with an inlet and outlet and piston movement.
- Case 1: When the piston goes down, we have mass flow at intlet and a closed outlet.
- Case 2: When the piston goes up, we have a closed inlet and a pressure at outlet.
I have write the UDF for the movement of the piston.
I want to write a UDF for the inlet and outlet depending on the movement of the piston, i.e. when the acceleration is negativ (Case 1) -> mass flow of x kg/s ; when the acceleration is positiv (Case 2) -> pressure of X Pa
Do i have to use UDM Macros ? In order to change the type of the boundary (mass flow inlet to wall), may I have to use a Scheme file and the TUI-Command or use a journal file?
Thank you.
Maxime -
November 16, 2018 at 12:12 pm
DrAmine
Ansys EmployeeYes to change the kind of boundary you need to use scheme. So mixture of UDF and Scheme is required here. Or just use Dynamic Mesh Events to change a boundary type after certain time lasted.
November 16, 2018 at 12:25 pm
Max4
SubscriberThank you for your reply. I can´t use Events because I want to do it for a random velocity profil, but good to know that it exists.
In the UDF for the movement of the piston, I have defined the velocity. Can I just define a variable (e.g. acceleration = -sin(..*time)) which has no effect for this UDF, but which is mandatory for the inlet/outlet boundaries UDF? In order to use this variable (acceleration) for the UDF of inlet/outlet, may I have to use UDM?
Maxime
November 16, 2018 at 12:58 pm
DrAmine
Ansys EmployeeYes you can use the UDM's as placeholder for that.
2688
2138
1355
1140
462
