March 5, 2023 at 1:13 pm
pcsingh
SubscriberGood evening!
In my case, fluid flows from top to bottom through a vertical pipe. Because it is an axis-symmetric problem, I have chosen to solve it horizontally, as illustrated in the figure. The left side of the geometry is designated as the inlet boundary condition, while the right side is designated as the outlet boundary condition. I used 0 for the y component of gravitational acceleration. I'm not sure about the value of gravitational acceleration. What should I enter for the x component of gravitational acceleration?
March 5, 2023 at 1:22 pm
pcsingh
SubscriberOrigin is taken on the left side of the above figure (bottom point of the inlet).
March 6, 2023 at 6:56 am
SRP
SubscriberHi,
If you want the motion to go from top to bottom, or from +x to -x, you can use -9.81 in the x direction for gravitational acceleration.
Thank you
March 6, 2023 at 11:08 am
pcsingh
SubscriberThank you @SRP sir.
I have chosen the bottom point of the inlet as the origin and flow are happening from left (inlet) to the right (outlet), as shown in the figure. Then, in this case, the value of g will be 9.81 in the x direction. Please correct me if I am wrong.
Regards
Prakash Singh
3812
2607
1853
1244
600
