March 14, 2021 at 4:33 pm
hsienfahs
Subscriberncan you help me to determine what i should put the value of source term ( w/cubic meter)nknowing that i have a resistor 1200 watt with (3 cm diameter and height 13 cm )nheating water in a tank of volume 0.035 cubic meternnplease advise -
March 14, 2021 at 9:12 pm
hsienfahs
Subscriberi am designing a electric hot water storage tank volume 35 LITER and diameter of tank 21.1 cm and height 100 cm nand i want to use a source term ( resistor ) nso my issue is to know this valueplease advise -
March 14, 2021 at 9:46 pm
YasserSelima
Subscribern(1200 / Volume ) where the volume is the volume of the resistance only if you adding adding the source to the volume of the resistor onlyn
Trending discussions
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
