Values in a graph
    • Deepesh
      In this graph, how do I find a particular value on x axis w.r.t to y axis value?
      Suppose I want to know value of Frequency (X axis) at 1.40 e^-6 (Amplitude Y axis) (As this Y value is not directly seen on the axis. It is 1.25 e^-6 thats visible on y axis)
      Is there any way to find directly in ansys workbench ?
      Credits: Picture taken from peteroznewman Sir's this answer https://forum.ansys.com/forums/topic/pre-stress-and-no-pre-stress-condition/
      Thanks
    • peteroznewman
      Next to each Graph is a Tabular Data window. Every point on the graph is in the table.  You can select all the values in the table and copy them to paste into Excel or any other program.
    • Deepesh
      Already did that Sir. As it is a bit time consuming as well as a lengthy process (Even using interpolation formulae came across my mind), thought if there is any direct way in Ansys itself to find out the values
    • peteroznewman
      No. Your best option is interpolation outside of ANSYS.
Viewing 3 reply threads
