February 27, 2023 at 2:35 pm
Fatih 1122
SubscriberHello, I'm doing aerodynamic analysis. I create the pressure contour. Is it normal for the values on the pressure scale to change when I change the number # of Contours?
February 27, 2023 at 4:05 pm
Ansys EmployeeMin/max or the ones in between?
February 27, 2023 at 5:00 pm
Fatih 1122
SubscriberAll change 30-100 Pa
February 27, 2023 at 5:01 pm
Fatih 1122
Subscriberall values on the pressure scale are changing
February 27, 2023 at 5:09 pm
Ansys EmployeePlease can you post some screen shots. Contour and the Panel settings used.
February 27, 2023 at 6:09 pm
February 28, 2023 at 9:31 am
Ansys EmployeeOK, look at the min/max on the Contour panel, they're all the same. Also, look closely at the scale on the image. The lower value is the same and ties up with the settings panel; the upper value is different but it's also not the final value on the scale. So, nothing wrong with the results, it's just a difficult option to spot.
Check with Contour 2 alone, having two picked at once in the display can do odd things. If you're using Fluent, do the post processing there.
As an aside, avoid spaces in filenames, directory structures, boundary conditions etc. It's good practice when dealing with engineering software as many codes are UNIX based so may not like spaces or other "odd" characters ( " £ $ { ] ) etc. Hyphen - and underscore _ are valid.
February 28, 2023 at 9:52 am
Fatih 1122
SubscriberThanks a lot
February 28, 2023 at 9:56 am
Ansys EmployeeYou're welcome. Good spot on the scale though, most wouldn't have noticed or questioned the difference.
3930
2649
1865
1272
610
