June 21, 2022 at 7:45 pm
kazisadman.kabir
SubscriberAnyone ever designed a commercially availble hyperabrupt varactor and tuned it electrically in HFSS?? Would really appreciate the help.
July 6, 2022 at 2:52 pm
Praneeth
Ansys EmployeeHi,
If you have the electrical characteristics, then you can import the model in Ansys Ciruit and tune it as required. Please let me know if this helps.
Best regards.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3648
2532
1745
1226
578
