Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Variable current in Ansys Maxwell external circuit
    • sahua1
      Hi ,
      I have to use variable current in my EM transient simulation . Currently I am applying the variable current as a data set in my simulation. But, now I want to add a circuit with inductance and resistance. While the external circuit provides those option , but I can only apply the current sources available. Is it possible to add a variable current source in the circuit , just like the data set in Maxwell.
      Thanks ,
      Ashish
    • Navya C
      You can use Piecewise Linear Current Source in the component library>sources for this purpose.
      Similarly, you have a Piece Wise Linear Voltage Source also.
      Regards Navya
    • sahua1
      Thanks a lot Navya. I got it now. This discussion can be closed.
