July 30, 2023 at 6:20 pm
Ata Vafi
SubscriberI'm looking for how to efficiently rename variable names on the HFSS design file (*.aedt).
Currently, the only way I know how to rename these variables is to do it manually, one by one, which can be extremely time-consuming, especially when dealing with numerous variables. Is there a more straightforward method or Python script that can automate this renaming process?
Thank you for your help! -
July 31, 2023 at 3:06 pm
GioF
Ansys EmployeeHi,
The local variables in HFSS can't be renamed in the local variable tab. However, you can create a new variable with a different name and assign the initial variable name as its value. This process can be automated with a Python script.
For more information on Variable Property scripting please refer to,
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7592
4440
2953
1427
1322
