TAGGED: ansys-fluent-solver, fluent, output-variables
September 18, 2023 at 4:57 am
Tom Walter
SubscriberI am a new user of Workbench and using Fluent to solve a simple pipe flow problem by following a video on YouTube https://www.youtube.com/watch?v=Wv9NRioSGDY&t=0s.
I have added "wall y plus" and "skin friction coefficient" from the data file quantities "other quantities" after the solver completed the calculation and before post-processing. Btw, I am using Workbench 2023 R1.
However, in my post-processing, there is no "skin friction coefficient" option but have "y plus" option. Did anyone encounter a similar issue? How can I resolve this problem? Thank you in advance!
September 18, 2023 at 7:05 am
Essence
Ansys EmployeeHello,
You can find the "Skin friction coefficient" under "Wall Fluxes" option.
September 18, 2023 at 7:31 am
Tom Walter
SubscriberThank you @Essence, there are only "wall heat flux" and "wall radiative flux" options in the post-processing step...
September 18, 2023 at 7:28 am
Tom Walter
SubscriberFinally, I realized that I should define its expression and then convert it to a variable in the post-processing. This is a difference between versions...
September 18, 2023 at 7:58 am
Essence
Ansys EmployeeI was referring to the contours.
7690
4476
2957
1435
1322
