VBScripting in Ansys Q3D extractor
    • bwide
      Hi Everyone,
      I'm trying to write a VBScript for Ansys q3d extractor .I have a DXF file that I wanted to import it into Ansys Q3D extractor, each time this file is changed in terms of number of conds
      for example: file1
      when I import it into the Ansys Q3d extractor software I got 69 cond
      file 2
      when I import it into Q3d extractor I got 72 cond
      so I would like to know how to merge the objects that intersect automatically because each time the number of objects changes from one file to another.
      That's what I want regardless of the number of objects file 3)
       here is the code that I did for a single file but I want it to automatically detect and test the conds that intersect and merge them since I have several different DXF files haven't the same number of conds.
      Thank you. Help me please
      file1
      file2
      file3
    • sv1437
      Hi bwide,
       Instead of using a script to do this. Try the below procedure:
       1) Select all the objects and unite them. Now they will be shown as single object in the Modeler tree.
       2) Now select the object and select the menu item Modeler > Boolean > Separate bodies.
       Let me know if you have any questions.
      -sv
