January 16, 2023 at 2:11 pm
Patrickodon
SubscriberHi all,
I was under the assumption that the colour of the vectors decided the "size" of them, i.e. the "amount" of velocity in the velocity vectors. But I'm running an animation and:
I've got colour descrepancies for the different vector values, but also different sized vectors - what does their differing size signify?
January 16, 2023 at 2:50 pm
SRP
SubscriberHi,
Vector is drawn at the center of each cell, with the length and color of the arrows representing the velocity magnitude.
I recommend to refer the user’s guide if you want more information on how vectors are represented.: 37.1. Basic Graphics Generation (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
Saurabh
January 16, 2023 at 3:04 pm
Patrickodon
SubscriberAh OK, I assumed only the colour represented the magnitude of the vector, not the size as well. Thank you!
January 17, 2023 at 2:49 pm
Patrickodon
SubscriberI couldn’t access the tutorial without the Ansys licence number (trying to source that off the college) – for anyone browsing in the future, I’ve figured out that the colour is the magnitude, while the size is the magnitude relative to the other arrows. So if there’s a large differrence between max and min, the size of max will be much larger than the minimum arrows.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
