July 10, 2020 at 10:18 am
Guillaume ANFOSSI
SubscriberHello,
Here's a question from one of our prospects:
"Is it possible to set a velocity based on pressure at that same point in DL or AIM ?
This would be extremely useful to me, because for vacuum pumps there is a linear relationship between flow rate and vacuum. So I could do a very consistent transient simulation."
Thanks for your help.
July 10, 2020 at 11:44 am
Naresh Patre
Ansys EmployeeHello GUICAD
I doubt this is doable, but let me cross check and get back to you.
July 14, 2020 at 2:12 am
Naresh Patre
In Discovery Live, it is not possible to set velocity based on pressure.
Regarding Discovery AIM, I got following suggestion from the development team:
It is possible to use an expression to define the Velocity based on a results variable. So, in theory, it is possible to define a velocity based on a calculated pressure at the same location. However, in practice, I think it would be very difficult to get a setup like this to converge. I would recommend starting off with a very simple steady-state flow solution to see if convergence could be obtained before trying this setup with the real geometry and a transient model.
Can you share the details of customer that is trying to setup this case? If you send the details to ansys-discovery-support@ansys.com
3862
2637
1859
1254
600
