October 16, 2018 at 6:19 am
October 16, 2018 at 6:24 am
Keyur Kanade
Ansys EmployeeHello,
For velocity inlet, you can define it by three methods. The defualt method of normal to boundary works in many cases.
If you have velocity components in x,y and z then you can use components option.
Keyur
October 16, 2018 at 6:54 am
DrAmine
Ansys EmployeeJust to add here: Setting the velocity inlet in a compressible flow is "lazy" as you may know this value but it's not the full boundary condition. Stagnation information for compressible flow are quite important.
October 16, 2018 at 7:03 am
rumth
SubscriberHi Keyur,
Thank you for your reply. While I am using normal to the boundary, the flow comes like straight line although my inlet is inclined.
Raju.
October 16, 2018 at 7:04 am
rumth
SubscriberHi Amine,
I am using incompressible flow.
Raju.
October 16, 2018 at 7:12 am
Keyur Kanade
Ansys EmployeeIf its straight line normal to boundary then using normal to boundary is ok. If straight line means parallel to axis then you may need to use components.
Keyur
October 16, 2018 at 8:32 am
Ansys EmployeeLooking at the image the inlet tube is at 15 degrees, but you've got the inlet plane perpendicular to the axis.
October 16, 2018 at 11:48 pm
October 17, 2018 at 12:09 am
rumth
SubscriberHi Keyur,
Your comment is not clear to me.
Raju.
October 17, 2018 at 3:17 am
Keyur Kanade
Ansys EmployeeHi,
With latest image, looks like your inlet is at 15 degrees. Its ok.
Now when you use normal to boundary option, it automatically will be at 15 degrees from axis. So I think you can go ahead and use normal to boundary option.
Keyur
October 17, 2018 at 4:23 am
rumth
SubscriberHi,
I am doing so but not getting the expected result !
Raju
October 17, 2018 at 4:26 am
Keyur Kanade
Ansys EmployeeCan you please explain more on expected results. What exactly you are looking at after running the case?
Keyur
October 17, 2018 at 5:59 am
October 17, 2018 at 6:26 am
Keyur Kanade
Ansys EmployeeI dont see any problem in this.
Can you please explain this in details. Please provide more details.
Explain your settings. Insert images of the geometry, mesh.
Keyur
October 17, 2018 at 9:05 am
Ansys EmployeeOK, I think it's a definition problem. In your sketch the nozzle is at 15degrees to the axis. In your (CFD) geometry the port are perpendicular to the axis. So, you've set the inlet correctly for the sketch but not the CFD geometry.
Either alter the CAD to mimic the sketch or use the components option in the velocity bc to set the direction as required.
2678
2120
1349
1136
461
