March 23, 2018 at 9:16 am
vaibhav jain
Subscribermy project is about buoyancy induced flow in inverted conical tube. i am getting too low values of velocity. what are the possible reasons.
March 23, 2018 at 11:08 am
SubscriberPlease provide more details, a screen snapshot and attach a project archive for further help.
March 25, 2018 at 11:02 am
Raef.Kobeissi
SubscriberIt is expected to have low-velocity values with a Buoyancy-induced flow. As Peter said , it would be nice if you can provide additional information about your case.
I also recommend you to read about the Boussinesq approximation for buoyancy.
Regards
March 25, 2018 at 11:08 am
Raef.Kobeissi
SubscriberPlease check this tutorial:
https://www.youtube.com/watch?v=_3wyysyWqsg
March 30, 2018 at 4:59 pm
vaibhav jain
Subscriberhi, i want to perform combustion of methane and air in vertical induced buoyancy inverted funnel pipe. i have to perform analysis using epsilon k model and non premixed combustion and second epsilon k model and species transport. energy equation is to be switch on i both conditions . take gravity and steady flow and axisymmetric. the problem i am facing is not getting converged results and results are not coming as expected in both species and non premixed combustion. both air and methane enters inlet but can't react. i dont know why? fuel and air are coming from same inlet. i am attaching a file of it. please look into it.
March 30, 2018 at 5:06 pm
vaibhav jain
Subscriber -
March 30, 2018 at 6:01 pm
vaibhav jain
Subscriberreverse flow problem may happen. i am also attaching other file having greater dimensions
April 1, 2018 at 8:15 pm
Raef.Kobeissi
Subscribercan you try and use outflow rather than outlet pressure?
Cheers
April 2, 2018 at 4:38 pm
vaibhav jain
Subscriberi have tried it but does not give favourable outcomes.
April 3, 2018 at 8:15 pm
raul.raghav
SubscriberVaibhav, the files you attached does not show how you set things up. Could you attach the workbench archive file that has the setup completed?
5324
3311
2471
