December 8, 2020 at 6:37 am
Lugia_06
SubscriberHi everyone,
December 8, 2020 at 11:34 amDrAmine
Ansys EmployeeOnly Water will result in Single Phase Behavior and VOF model should be able to handle it. nHowever running a pump with VOF after you add Air is more than questionable. nDecember 8, 2020 at 8:16 pmLugia_06
Subscriberif no air is added in and water only contact air at the outlet, would the water velocity within the pump still be accurate?nDecember 8, 2020 at 8:52 pmDrAmine
Ansys EmployeeYes. If you are providing correct pressure boundary at outlet.nViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
8726
4658
3151
1678
1450
