October 29, 2018 at 5:52 pm
seventanapply
SubscriberHi,
I am trying to verify the tan delta of viscoelastic material in Workbench. The model is simply a 10x10x10 mm cube. Transient structural is chosen.
For the part of Shear modulus and bulk modulus, I obtained the experimental data from DMA and import those data points into Engineering data. And I have already verified that if there is a constant stress, then a creep compliance curve is obtained which is matched with my experimental data of creep compliance.
For tan delta,
I measured the storage modulus vs freq curve from DMA and import those data into WB by APDL commands.
Then I set my pressure as a kind of sinusoidal pressure upon the top surface. The function of pressure is as follow.
Pressure=-0.4*sin(6.28*time) if pressure<0
otherwise pressure=0.
Those data are imported by XML file. I am pretty sure the pressure is correct. Here is the screenshot.
Other boundary condition is a fixed support at the bottom.
According to the definition of tan delta, delta is a lag phase angle between stress and strain if the input is a sinusoidal stress.
But I cannot see any phase lag in my results.
Can you give any suggestions? or maybe I made some conceptional mistakes? Should I do it under Harmonic analysis?
Thanks in advance.
February 27, 2019 at 8:42 am
caogang7758
SubscriberI recently also find out that transient structural analysis does not shown any phase lag and energy dissipation when you use prony series viscoelastic.I feel puzzled.
2142
1355
1144
462
