September 7, 2023 at 10:12 am
Martina Lazzari
SubscriberHi,
I'm using Maxwell Student 2023 R1 to run a simulation AC Conduction for testing an interaction between blood and two electrodes, but when I enter the dielectric characteristics of blood and I run the simulation, it stop working and shows the following error:"Verify conduction path 'Path1': if a conduction path contains current exitation(s), it must contain at least one Voltage or Sink exitation but not both"
Concerning excitations I'm using two electrodes, one with a current on the lower face and the other one with a sink, always on the lower face.
How can I check where the problem is? -
September 11, 2023 at 5:59 pm
Reshmi Raghavan
Ansys EmployeeHello Martina,
Please check the below points.
1) Are both the electrodes part of a single conduction path? - check the conduction path
2) If they are not part of a single conduction path current in and sink has to be defined for both the conductor.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7592
4440
2953
1427
1322
