August 20, 2019 at 5:46 am
Alhussein
SubscriberHi,
I'm using Transient Thermal in workbench to simulate heating of an embedded metal ring using radio frequency. I'm using a thermocouple inserted near the ring to measure its temperature but I'm worried that the electromagnetic field from the ring is affecting the thermocouple reading. I also can't use a thermal camera because taking out the ring from the material surrounding it would affect the results. So far, the results from the thermocouple and the model don't seem to agree very well. My question is how to verify that I'm getting accurate results from the model knowing that I don't fully trust the measurements? Like, is using stagnant air (simplified case) good for film coefficient? Is my imported load transferred correctly? Any help would be appreciated and I'm also open if anyone has a better way to measure the ring temperature.
August 30, 2019 at 10:14 am
Ansys EmployeeIt's likely that the Thermal model is correct (assuming convergence) for the given input. However without a detailed look at the experiment (which I'm not allowed to do) it's anybody's guess whether you are modelling the experiment.
August 30, 2019 at 11:38 am
SubscriberThis article recommends using a Resistance Temperature Device instead of a thermocouple when taking measurements in a strong electromagnetic field.
- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- 3D ROM in workbench
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2524
2066
1279
1096
457
