February 9, 2023 at 5:24 pm
CFXUser583
SubscriberHello, Is there anywhere I can download the 2021 student version?
February 10, 2023 at 11:10 am
Ansys EmployeeNo. Only current and two previous releases are available.
February 10, 2023 at 11:15 am
CFXUser583
SubscriberThank you. Is it possible to receive acces to the 2021 version?
If not, perhaps you could suggest a different solution. I want to run a parametric study in CFX (for which I believe I need workbench). I want to run the simulation on an external cluster which only has workbench 2021. I therefor am unable to run the workbench files which I prepare on my pc which has workbench 2022.
February 10, 2023 at 11:33 am
Ansys EmployeeYou've only got 2022 R1 & R2 or 2023R1 for Student. If you're switching to an external cluster please use the University licences to build the models. Student is to give you more opportunites to learn how to use the code, it's not intended to supplement or replace the University supplied software.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3812
2593
1849
1244
600
