September 3, 2018 at 3:57 am
Moh1993
Subscriber -
September 3, 2018 at 4:11 am
Keyur Kanade
Ansys EmployeeHi,
Please change cell zone type to fluid under cell zone conditions.
Let me know if this helps.
Keyur
September 3, 2018 at 4:21 am
September 3, 2018 at 5:33 am
DrAmine
Ansys EmployeeCan you go after initialization to the Mesh interfaces and list the interface to check the portion of overlapping and non-overlapping regions on your interface. The same can be done via Graphics under Mesh variables (Interface Overlap Fraction).
September 3, 2018 at 6:32 am
Moh1993
sorry i cant understand how to do that , im using fluent 18.1
September 3, 2018 at 7:33 am
DrAmine
Ansys EmployeeSo you have understood it otherwise you were not able to post it. So it tells that only 28.5% of the interface is marked as interior which would explain the flow blockage (which could result from different mesh topologies, geometric misalignment, or the existence of large gaps). Please post a zoomed screenshot of the mesh where the interface might be checked.
September 3, 2018 at 7:59 am
September 3, 2018 at 8:09 am
DrAmine
Ansys EmployeeSo the mesh is depicting some regions with gaps and regions of misalignment and regions where both parts are overlapping each other. Either you go back to pre-processing and work on that (recommended) or (if really the interfaces needs to be 100% flow permeable) you can try recreating the interface with the Option "Matching" (I underline the word "You can Try")
September 3, 2018 at 9:48 pm
Raef.Kobeissi
Subscriberis it safe to assume this is a 2D mesh?
2726
2148
1357
1150
462
