April 14, 2022 at 4:45 am
Mariah Ha
SubscriberHello,
In the vertical photodetector lumerical example , when extracting the current from the cathode side, it is multiplied by a factor of 2 . Can anyone explain this please? Normally the total current in the cathode should be extracted without further multiplication if it refers to the total current , right ?
April 19, 2022 at 6:29 pmKhashayar Ghaffari
Ansys EmployeeViewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
