April 25, 2023 at 4:43 pm
Edward Suh
SubscriberHi,
I created one simple via in 3D Layout. There are three signal layer; top, inner, and bottom layer. The via was created from top to bottom layer, but the pad looks missing in the layer "3". I am seeing the Pads of Top and Bottom layer, but not in layer "3". Is it really missing or is there an option to turn on the pad in the middle layer?
Via info
Stackup
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2471
