November 3, 2018 at 12:35 pm
Luis
SubscriberHello everybody, I've performed a FSI simulation between fluent and transient mechanic to find flow vibrations induced by rotating propeller and rotating shaft on the strut. My output now, in workbench, is the tab ''system coupling". How to find vibrations induced (contour and amplitude-frequency plot)? thank you
November 3, 2018 at 1:43 pm
SubscriberIn Mechanical, pick a node on the strut, maybe near the tip, or one that is level with the shaft, either side will do. Request Directional Deformation and select a coordinate direction that represents the sideways vibration of the strut. Go to the Tabular output and copy the data out of the table and paste it into a program that can compute an FFT or a Spectrogram or Waterfall Plot to extract the frequency content of the deformation. I use matlab for that. What was the time step size of the system coupling?
November 7, 2018 at 2:23 pm
Luis
SubscriberHi peteroznewman, thank you for your kind reply. I used 1*10^(-4) as timestep size. When I request "directional deformation" and plot the data, I will obtain a graph (or chart) containing deformation (mm) vs. physical time? Then, using FFT I can switch to frequency domain? Am I right?
Thank you
Luis
2146
1357
1150
462
