view factor into a radiation simulation
    • eugenio benedetti
      Hi forum
      I'm Eugenio. I'm doing an high number of steady state thermal simulation with radiation. I saw on the solution information that ansys write the view factor calculated into a file.
       WRITING VIEW FACTORS TO FILE
      file.vf
      I need to change material properties or boundary condition, not the geometry.
      there's a possibility to re-use that view factor? It willl be decrease a lot the time of each simulation.
      thank you all
    • Ashish Kumar
      Forum Moderator
      Hi Eugenio,
      Try using the VFOPT READ command.
      Ashish Khemka
