March 6, 2021 at 5:54 pm
gouthambraj
SubscriberMarch 17, 2021 at 4:56 am1shan
Ansys Employee,nnIn the last image it looks like you might have inserted the wrong elastic moduli. Could you check the data that you have inserted for the neo-hookean model especially the units? For small times your hyper elastic and visco elastic models should give you nearly the same result (which I dont see).nnRegards,nIshan.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2532
2066
1285
1104
459
