September 27, 2018 at 11:28 pm
learn13
SubscriberI'm having difficulty finding material definitions fitting a viscoelastic foam within ansys or within the many online resources.
Using Prony seems an absolute must, however I do not have data to input in order to model viscoelasticity. Ideally, modifying structural steel NL would serve as a great start.
Thank you.
September 28, 2018 at 3:20 am
Keyur Kanade
Ansys EmployeeIt looks like question on ANSYS. Should I move this to Structural Mechanics so that you would get better reply.
Keyur
September 28, 2018 at 3:58 am
learn13
SubscriberGreat suggestion! If you think it will help, I would appreciate it.
September 28, 2018 at 4:00 am
Keyur Kanade
Ansys EmployeeOk. Then I am moving this to Structural Mechanics category.
Keyur
September 28, 2018 at 7:55 pm
Sandeep Medikonda
Ansys EmployeeHi,
I would recommend you to axelproducts or datapointlabs for material data.
Yes, you would need to fit the data using prony-series parameters.
You might want to fit your data to a hyper-elastic material model such as Ogden 3rd or 4th order first? Structural Steel behavior is no way close to how a foam material would behave. One of the biggest challenges in capturing Foam materials is to account for the incompressibility.
For just hyper-elastic data we have a group of materials you can start with in Engineering Data Sources itself.
Sandeep
Best Practices to post on the Student Community -
October 5, 2018 at 12:42 pm
Ashish Khemka
Ansys EmployeeYou may also refer to one of good article here:
http://ansys.net/collection/1113
Ashish Khemka
2104
1327
1110
461
