March 14, 2021 at 5:26 pm
OmkarE11
SubscriberCan anyone tell me how to add long term shear modulus as material property in ANSYS for carrying out explicit dynamics? n -
March 16, 2021 at 10:45 am
1shan
Ansys EmployeenAfter you define the experimental data for shear modulus and/or bulk modulus as a function of time, and perform the fitting process, the prony coefficients are obtained. The long term shear modulus (first term in prony series) would be calculate from these prony coefficients. Check out the help documentation - 4.7. Viscoelasticity (ansys.com) and 6.2. Viscoelastic Material Curve-Fitting (ansys.com). nRegards,nIshan.nn
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
