March 7, 2021 at 5:07 am
far29
SubscriberHello, nI have a pressure ratio versus frequency graph from literature that I want to fit in the parameters of my viscoelastic material in my transient analysis. I will be using the Prony series. I know that to do curve fitting for Prony series I need the shear modulus versus time graph. I know how to get damping ratios from my data but I have no clue as to how to turn that into the shear modulus so I can do the curve fitting. Any help? Or should I change the way of thinking this whole thing? nThanksn -
March 8, 2021 at 9:38 am
1shan
Ansys Employee,nYou will need the shear relaxation test data or the values of storage and loss modulus vs frequency. Please have a look at https://forum.ansys.com/discussion/3105/viscoelastic-sandwich-plate-analysis and https://forum.ansys.com/discussion/2491/modelling-visco-elastic-material-for-harmonic-response-analysis. I don't think you can derive shear modulus using the data for pressure ratio.nRegards,nIshan. n
Trending discussions
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
