March 26, 2023 at 10:42 pm
nihayatun nafisah
Subscriberwhat is the difference from the viscous model of Spalart-Allmaras, k-epsilon, k-omega, transition k-kl-omega, transition SST, Reaynolds stress, scale adaptive simulation, detached eddy simulation, large eddy simuation? And what the general usege that common use?
Thankyou
March 27, 2023 at 8:23 am
Raihan Lutfianto
SubscriberYou may find the explanation here:
https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node1022.htm
It may be from the older version, but it still can be used in general
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Viscous Models
- Torsion Stiffness
5200
3275
2457
