Tagged: gaussianbeam, Lumerical-FDTD, python, scripting, source-data
April 11, 2022 at 4:57 am
IanFMZ
SubscriberHi,
One way of obtaining the beam data for a source is by clicking "Visualize beam data" for the source, then exporting to various formats from the visualizer. We can also reach the visualizer by clicking Visualize -> Fields.
April 11, 2022 at 6:40 pmGuilin Sun
Ansys EmployeeI am not sure how to do this in Python, but using Lumerical script you can do it. For example source_field=getresult("source","fields");
in the workspace you can see the dataset:
An even better way to do this is to use script add the Gaussian source, set its parameters and extract the field data as above.
eg addgaussian;
set("wavelength start",.5e-6);
set("wavelength stop",.6e-6);
set("waist radius w0",3e-6);
Then you can further process what you want to do.
April 12, 2022 at 11:25 pmIanFMZ
Thank you, that is exactly what I was looking for!
In Python, it can be done using
fdtd_hook = lumapi.FDTD fdtd_hook.getresult("source", "fields")
which will output the dataset as a dictionary with keys ['lambda', 'f', 'x', 'y', 'z', 'E', 'H', 'Lumerical_dataset'].
April 13, 2022 at 12:01 amGuilin Sun
Ansys EmployeeThank you for letting me know this!
- Error on Lumerical device
2726
2156
1359
1150
462
