Visualize the crack propagation
    • Abdoon075
      I don't know why I can't view the crack propagation, Although SIF is greater than fracture thoughness
    • peteroznewman
      ANSYS can calculate the SIF and you can see that it has exceeded the fracture toughness, but it doesn't automatically propagate a crack when that happens.
    • Abdoon075
      but I found a lot of example that view the crack propagation
    • peteroznewman
      Yes, but you have to add more to a model to propagate a crack than you need in a model to just calculate SIF.  Many times, you don't need to see the crack, you just have to know that a fracture would have occurred at some load.
    • Abdoon075
      Well, Mr. Peter
      What should I have to add to the model ??
      Sometimes I need to calculate the extension of crack
    • Abdoon075
      well,  what should I add to get that ??
      Can Ansys calculate the crack extension ?? How I do that ??
    • peteroznewman
      Follow every step in the video and you will get the same result.
Viewing 6 reply threads
