Ansys Free Student Software
VKI license is not available
    • Dichany
      VKI license is not available. Corresponding TUI and GUI options for import and export will not be available:
      This  is the message I get, when I open fluent after meshing. Can someone tell me what tha means? The meshing is not good?
      Dichany
      It shouldn't make any difference to you. Which version (and licence) are you using?
    • Dichany
      I'm using a student version(2019 R2).
    • eayom1
      I'm having a similar problem. The message "VKI licence is not available. Corresponding TUI and GUI options for import and export will not be available" reads in the console and "No licence for Fluent Application" box pops up that prevents me from doing anything in Fluent except closing it. I am using the 2019 R3 student version.
      The VKI part relates to a reader, and shouldn't effect the running of the software.
      eayom1, please can you post a screen grab, especially of the pop up and text in the main Fluent window.
    • eayom1
      After restarting Fluent and c1950.exe I am no longer getting the licencing issue, although the VKI message still shows in the console, but I am able to use the program now.
    • PRABUPETER
      Hi eayom1,
      I also have the same issue. What is c1950.exe. how did you get rid of this error
      kindly explain.
Viewing 6 reply threads
