Ansys Products
Ansys Products
VKI license may make a vector problem at fluent
    • Elad
      when i open fluent the announcement appear (under console with the ansys 19R version):
      "VKI license is not available. Corresponding TUI and GUI options |
       for import and export will not be
      i did search the meaning and the influence, i read that it not need to effect on the simulation. But I get different velocity vectors in the simulation, one of them looks good when in the other I can see nothing.
      with the the same file(wbpj), at the good pic of velocity i am using ansys 18 and the other i am using ansys 19R. The contour looks the same.
      i did use at the past with thermal and structure simulation at 19R version and didn't see a problem.
      i would like to get help.
      Elad
      available."
    • Elad
      the image simulation from Ansys 18:Ansys vector 19R
      Shouldn't do. VKI is a licence for something which I can't remember but is unlikely to affect anything you do. The vector scale looks to have changed: it's controlled on the vector panel. Thanks for flagging up though!
    • Elad
      hii rwoolhou,
      thanks for answer.
      I am attaching a picture of what I believe a panel vector.
      The marked display options are the same, I'd love to know what might be the problem so I can work with Ansys 19.SIM ANSYS 18 VS SIM ANSYS 19
      In the main Vectors panel drop the scale down to 0.1 and display, then try 0.01 etc.   Scaling is based on velocity range so if the newer solver has tidied up one rogue value the scaling can look a little silly.
Viewing 4 reply threads
