March 28, 2022 at 3:05 am
Rusbel.Ayala
SubscriberIs it possible to determine drag force between particles on a VOF model?
I have an 2d (air) domain with a droplet, patched via volume fraction.
I have set up the drag force that the wall will experience over time. However is it possible to track the droplet over the plate, and give the drag?
Using a custom UDF, or another method?
March 28, 2022 at 1:51 pmRob
Ansys EmployeeYou want the drag on the free surface? You can get the pressure on the iso-surface but not sure if the facet normal (assuming there is one) is stored to let you get any vector information.
March 31, 2022 at 2:33 amRusbel.Ayala
SubscriberThank you for your response. I am trying to determine the lift and drag force the droplet experiences as it rolls, detached, and reattaches along a surface.
I am trying to make lift vs time, and drag vs time plots. As the droplet moves through the domain.
Mentioned VOF model is not compatible with DEFINE_DRAG_FORCE. particle_drag_force.
Is there a method of determining these values?
Thank you, truly
March 31, 2022 at 1:30 pmRob
Ansys EmployeeYou're tracking an isosurface of phase. I'm not sure the force vector is available, so you may need to calculate from something using a UDF. It's very definitely not simple. It's also not going to roll as the liquid is likely to wet the wall surface.
March 31, 2022 at 8:01 pmDrAmine
Ansys EmployeeDrag over the wall is straightforward via Report definition
March 31, 2022 at 8:02 pmDrAmine
Ansys EmployeeAlong the droplet you need to get shear rate and pressure and do the whole math to get shear stress and pressure force to derive drag and lift.
April 5, 2022 at 12:46 amRusbel.Ayala
SubscriberBy my understanding I could save additional data quantities in fluent such as: strain rate, static pressure, pressure coefficient, dynamic, absolute, total, and relative total pressure to further analyze in Post. and provide some code to determine the drag and lift force.
However, the location of the droplet is crucial to determine these values in post, correct?
I would have to determine a function or location after every droplet, such tracking a particle through the domain, or selecting a point in post to determine the drag and lift force?
Thank you in advance!
April 5, 2022 at 5:37 amDrAmine
Ansys EmployeeYes location is important.
April 5, 2022 at 5:39 amDrAmine
Ansys EmployeeYou need to identify each droplet that is challenging. We gave lump detection feature which might be helpful and still require coding but I need to understand your final goal: what do want to do and why?
April 5, 2022 at 7:37 amRusbel.Ayala
SubscriberI will look into lump detection.
I am ultimately trying to determine the lift and drag forces of a droplet over time, in order to cross referencing my simulation methods and data to reference experimental data.
The aim is to validate current simulations to experimental results. I am aware that at high air speeds, the droplet shape/surface tension breaks which would cause lots of problems with determining a lift force for example. But a spherical droplet traveling through space is the idea.
I hope to further analyze other droplets, with varying properties and derive data from this.
Thank you once again Dr. Amine!
April 5, 2022 at 5:42 pmDrAmine
Ansys EmployeeDo you have a single droplet?
April 5, 2022 at 7:02 pmRusbel.Ayala
SubscriberI have 2 droplets that are static - a certain distance away from one another. They then merge into one another, forming a single larger droplet.
Cheers
Viewing 11 reply threads- You must be logged in to reply to this topic.
2616
2098
1321
1108
461
