December 1, 2020 at 10:05 pm
neelshah0034
SubscriberTo whom it may concern,nIn the webinar of VOF-Lagrangian hybrid spray modelling by Mr.Muhammad Sami, there were some results shown from a jet in a cross-flow simulation. He mentioned that the validation case are available only upon request. May I know were can I find those validation cases. If it is are not available, I am looking to find out more information regarding meshing and boundary condition used to obtain the shown results. I am trying to replicate the simulation for better understanding. Specifically, I am more interested towards the turbulence model used, the inlet velocity profile and the size of the domain (SMD). nWaiting for your prompt replynThanks youn -
December 2, 2020 at 1:21 pm
DrAmine
Ansys EmployeeGet an access to the learning Hub and you will find a recent workshop dealing with LJCF where we are comparing the SMD to experimental values at some planes.n -
December 8, 2020 at 6:42 pm
neelshah0034
SubscriberThank you Sir for sharing the information.nCould you please provide me the link from where can I get access to learning hub?nThank younNeel Shahn -
December 8, 2020 at 7:15 pm
DrAmine
Ansys Employeehttps://www.ansys.com/de-de/services/learning-hubn -
December 8, 2020 at 8:01 pm
neelshah0034
SubscriberThank you Sir,nnHowever, as a student I won't be able to invest such a huge amount. nI would request you to please let me know, if their is any other way to get some information for the same.nEmail Id:- neelshah0034@gmail.com|shahn3@my.erau.edunnThank younNeel Shahn -
December 8, 2020 at 8:54 pm
DrAmine
Ansys EmployeeHere a video we created last year: https://youtu.be/S0MUu2svgQ8n
- The topic ‘VOF-Lagrangian Hybrid Spray Modelling validation cases’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
