December 4, 2020 at 9:31 pm
A1234
SubscriberHello
What is the best method for VOF?
I simulate drop impact to flow and i just want to refine drop not other interface.
December 7, 2020 at 9:31 am
System_delete
SubscriberThis discussion was created from comments split from: How to use adaptive mesh function in ANSYS 2020 R1 (ANSYS Fluent). -
December 7, 2020 at 9:33 am
Forum Moderator
VOF is a method, ie it's one of the multiphase models. When you say drop impact, are you looking at droplets splashing, or do they form a film? With multiphase modelling (all models to slightly lesser extent) you need to understand what is going to happen before switching the software on as the physics influences the mesh too.
December 7, 2020 at 9:43 am
A1234
Subscriberthanks
i simulate splashing
December 7, 2020 at 11:17 am
Forum ModeratorFor splashing you'll probably want VOF but given the mesh resolution you may also want to look at VOF to DPM.
- The topic ‘VOF method’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
