September 21, 2018 at 1:55 am
98546948
SubscriberHello everyone,
I'm doing a simulation about evaporation and condensation using VOF Model in Fluent. I compiled a UDF of primary phase for mass conservation. But It seems that the UDF doesn't work. I'm confused that whether the continuity equation of primary phase was solved at every time step?
Kindly help me out
Thank you.
September 21, 2018 at 8:58 pm
mli
Ansys EmployeePlease provide more details of your model.
September 22, 2018 at 4:02 am
98546948
SubscriberThanks for your time. Actually, the simulation was performed by Evaporation and Condensation Model of VOF Model in Fluent. The Lee Model was used to calculated the mass transfer rate. The rate of evaporation and condensation is calculated ,respectively. In a seal container, the mass increase caused by evaporation is equal to that by condensation. But it's not easy that the coefficient of evaporation and condensation is turned to match experimental data. So, I compiled a source UDFs, which adding two equations to guarantee that as much liquid disappears, as much gas is produced. And the source equations are described as follows:
In Fluent Help, there is some describtion like this:
So, I'm confused that whether the continuity equation of primary phase was solved at every time step in UDFs?
Thanks for your help again.
September 22, 2018 at 10:18 pm
Karthik R
AdministratorHello,
You are correct, Fluent does not solve the volume fraction equation for the primary phase. It only solves it for all the secondary phases. The volume fraction of the primary phase is obtained by subtracting the sum of secondary phase volume fractions from 1. All your source terms are appended for the secondary phase VF equations.
I hope this answers your question.
Thank you.
Best Regards,
Karthik
September 24, 2018 at 6:39 am
98546948
SubscriberOh,It's really not a piece of good news that the source equation of primary phase be not solved.
Anyway, Thanks for your reply.
Best wishes.
September 24, 2018 at 8:09 am
DrAmine
Ansys EmployeeThe more general Eulerian Model has the option to solve N continuity equations. You might use if you think you could have better results.
September 25, 2018 at 3:06 am
98546948
SubscriberThanks for your recommendation.
2726
2148
1359
1150
462
