September 21, 2022 at 9:12 pm
ovm0002
SubscriberHello,
Please, I am running a simulation with three phases and inlets, air, water and PCM. Water comes in at a high temperature to melt the PCM, air gets compressed because of this. I run it to about 4.5secs and I shut off the inlets and allow the water melt the PCM. I noticed that when I shutoff the inlet, air volume increases(which is not meant to be so) while pressure and temperature decreases. I also noticed that water volume decreases which is weird and wrong because my system is incompressible(boussinesq). I don't know how to solve this problem, can someone please suggest to me how to fix this?
Thank you.
September 22, 2022 at 9:57 am
Ansys EmployeeAs a guess you're losing mass of another phase? This is typically caused by a mix of convergence and mesh resolution. During the earlier stage, if water is coming into the domain and PCM is already present where does the air go?
September 22, 2022 at 2:28 pm
ovm0002
SubscriberNo the air doesn't go. In the earlier stage, we have a case of Adiabatic compression, the air gets compressed while the water volume increases because there's a steady addiition of water at the inlet.
September 22, 2022 at 2:43 pm
Ansys EmployeeBut if air is fixed density what happens? Consider the physics, not just the simulation theory.
September 22, 2022 at 2:45 pm
ovm0002
SubscriberThe air is taken as an ideal gas from the onset of the calculation, which makes it behave to be adiabatically compressed.
2706
2146
1357
1148
462
