VOF solution with 2nd order momentum not stable
    • fit78
      I'm working on fluid film on horizontal tube but the solution by using the 2nd order momentum resulted in the breaking of the film as shown in attached figure.
      I tried to decrease relaxation factor of the momentum to 0.01 but to no avail.
      I'm wondering if anyone has any suggestion to go about this.
      I tried to stabilize the film by changing to k-e mid iteration and the film stabilized but didn't work when I changed back to laminar.
      Settings used:
      VOF implicit, laminar, SIMPLE,Body force weighted, compressive volume fraction, second order upwind momentum, the rest is first order.
    • Karthik R
      Administrator
      Hello Firstly, what do you expect to see in this problem? I don't quite understand the problem you are trying to solve?
      Before you change your discretization options, are you making sure that you are converging every single time step? I ask this question because the time-step chosen in your simulation, 0.2 s, seems a bit high for such problems. What is your CFL number? You might need to reduce this further.
      Karthik
    • fit78
      Hi I'm trying to reduce the film thickness based on some literatures of the same liquid load. I'm using implicit so the CFL number is not an issue I hope. I could get film thickness of within 40% of those in literature but I'm trying to reduce it by using second order momentum. Perhaps this is the limit of implicit solution.
    • Karthik R
      Administrator
      If you are comparing solutions with literature, I'd go the 'Explicit VOF' route and reduce the time-step to keep the CFL number close to 1.
Viewing 3 reply threads
