VOF tank filling/emptying – divergence during emptying
    • desouzadacosta
      Hi All
      I am trying to simulate a tank filling from the bottom, valve opening and emptying .
      The filling is going fine, but after the opening of the valve, the emptying operation is showing divergence in the k field :
      Global Courant Number [Variable Time Step Criteria] : 7.135128
      Updating solution at time levels N and N-1.
       done.
       physical-dt  1.0000e-05
        iter  continuity  x-velocity  y-velocity  z-velocity           k       omega    vf-water     time/iter
       reversed flow in 259 faces on pressure-outlet 14.
              Stabilizing k to enhance linear solver robustness.
      Error: Divergence detected in AMG solver: k
      Error Object: #f.
      I already tried the turbulence damping, k-epsilon, k-omega, implicit/explicit VOF, reduced time step, options without success.
      I reproduce below some pictures of the simulation. Any expert advice is very welcome.
    • DrAmine
      How is the opening of the valve modeled? Switching boundary condition? When dies divergence occur?
    • desouzadacosta
      Thanks for the reply. It is changed from wall to interior using execute commands, after some volume of water is reached.
    • DrAmine
      And when does it diverge?
    • desouzadacosta
      At t = 3.672 s
    • DrAmine
      Ok. What is the boundary condition applied in the bottom? Try with Tait equation for water.
    • desouzadacosta
      Sorry. How to use Tait equation?
    • DrAmine
      Compressible liquid.
Viewing 7 reply threads
