VOF-to-DPM
    • Renard
      I would like to know if VOF-to-DPM module can be used to change the injections from DPM to VOF, I've seen in some tutorials only the opposite (VOF-to-DPM) and I wonder if it's possible to set is as "DPM-to-VOF".
      And if it's possible to use it on 2D mode.
      Many thanks
      Manu
      Also if there are more resources to learn how to use the module.
    • DrAmine
      No. The model transformation is to covert Eulerian Lumps into Langragian particles. The manual contains all necessary input to get started.
    • Renard
      Ok many thanks for your answer.
    • DrAmine
      You are welcome. It would be kind if you mark this topic as solved.
Viewing 3 reply threads
