Voltage data extraction in Workbench
    • ngarcia_ncs
      Hello everyone,
      I am working with a Transient-Structural and Fluid flow Fluent simulation with a Piezo-MEMS extension. My main problem is I'm having trouble processing the results. My model is a liquid layer against a solid steel bar with a piezoelectric receiver. A force is transmitted through the liquid layer to produce acoustic waves in the liquid which are transmitted to the steel. The piezo receiver converts the ultrasound to voltage. This is the workbench setup:
    • Sheldon Imaoka
      If you open the results in Mechanical, add a User Defined Result for "VOLT", which will give you a contour plot of voltage. You can scope it to a specific location (not just the entire model), and the graph on the bottom will give you the voltage vs. time.
      Regards Sheldon
